Inventor Forum
Creating Adaptive Part
5 REPLIES 5
Ehsancad
480 Views, 5 Replies
Hi all
I have a Flange with some holes distributed as circular pattern.
I put it in Assembly file & I want to add adaptive gasket on it by using Create Part Command in assembly.
I put a sketch on the red face and create extrude for project geometry of this face by 3 mm.
I found the the outer Diameter is just the only Adaptive.
If i change the number of holes ,it doesn't change automatically on the Gasket(new Created Part).
How can i make the number of holes related between gasket and flange?
5 REPLIES 5
delineryan
in reply to: Ehsancad
I used the derived part command, exported the number of holes parameter. I have attached the files.
Ryan
BMiller63
see this link also:
http://discussion.autodesk.com/forums/thread.jspa?messageID=5916090?
link above didn't seem to work, try this one:
http://discussion.autodesk.com/forums/thread.jspa?messageID=5916090䖺 Edited by: Bmiller63 on Feb 1, 2010 2:44 PM
Ehsancad
Thank alot
Ehsancad
How can we export Number of holes Parameter from flange to Gasket,in order to reuse it again?
delineryan
Check off "Export Parameter" in the "Parameters" window. See pic,
Ryan
