Show only
Search instead for
Hi all
I have a Flange with some holes distributed as circular pattern.
I put it in Assembly file & I want to add adaptive gasket on it by using Create Part Command in assembly.
I put a sketch on the red face and create extrude for project geometry of this face by 3 mm.
I found the the outer Diameter is just the only Adaptive.
If i change the number of holes ,it doesn't change automatically on the Gasket(new Created Part).
How can i make the number of holes related between gasket and flange?
see this link also:
http://discussion.autodesk.com/forums/thread.jspa?messageID=5916090?
link above didn't seem to work, try this one:
http://discussion.autodesk.com/forums/thread.jspa?messageID=5916090䖺
Edited by: Bmiller63 on Feb 1, 2010 2:44 PM
