Inventor General Discussion
Member
newguymike
Message 1 of 3 (807 Views)
creating a special material (fragile polymer honeycombs)?
807 Views, 2 Replies
03-16-2011 02:01 PM
I am rather new to the 3ds max. I am trying to recreate a material that is porous. It really looks like a very fragile and papery honeycomb. I was figuring I could create a bunch of planes and put there vertices together and make a special bump map that could recreate this type of material. On looking through some forums, some people mentioned they used a particle generater to create spongy like materials, or something of a volume shadow?. Does anyone have any good suggestions on where to get started are where I can learn some of these techniques.
Mike
newguymike wrote:
I am rather new to the 3ds max. ...Does anyone have any good suggestions on where to get started are where I can learn some of these techniques.
http://forums.autodesk.com/t5/Autodesk-3ds-Max/Autodesk-3ds-Max-Discussion-Groups-are-on-the-AREA/td-p/2692186
JDMather
Message 2 of 3 (800 Views)
Re: creating a special material (fragile polymer honeycombs)?
03-16-2011 02:05 PM in reply to: newguymike
http://forums.autodesk.com/t5/Autodesk-3ds-Max/Autodesk-3ds-Max-Discussion-Groups-are-on-the-AREA/td...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
newguymike
Message 3 of 3 (798 Views)
03-16-2011 02:06 PM in reply to: JDMather
sorry i posted this on the wrong thread i believe
