Inventor General Discussion
sinus19
Message 1 of 9 (394 Views)
Creating a Sharp Fold
394 Views, 8 Replies
08-24-2012 11:25 AM
I am trying to fold a sheet into an "L" shape (using the the Fold command) but i would like to have the inside of the bend to be sharp and not a radius like on the outside. Is there any way that i can achieve this?
sinus19 wrote:
.... Well at the shop we have a hydraulic break that uses sharped end dies and when it bends a sheet it leaves a sharp crest on the inside but a round bend on the outside.
No matter how sharp it is - there is still an inside radius.
Check the resulting part on an optical comparitor or under microscope.
*Pro
jletcher
Message 2 of 9 (385 Views)
Re: Creating a Sharp Fold
08-24-2012 11:40 AM in reply to: sinus19
The only thing is .001 radius...
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Contributor
sathersc23
Message 3 of 9 (384 Views)
08-24-2012 11:41 AM in reply to: sinus19
The inner bend radius and outer bend radius are tied together like they would be in real life. You can try setting yoru bend radius to nearly zero (I've never tried) and see what that does for you. Most things in life though that are folded have a bend radius of something to it. If you're forming a piece using a different process, you probably want to try a different modeling method.
Sam Sather
CAD Admin/Designer
Inventor 2012
Vault Pro 2012 16.1.58.0
Intel Xeon X5690 @ 3.47 GHz
12.0 GB Ram
Windows 7 x64
AMD FirePro V7900 - 8.830.5.6000
"We have not succeeded in answering all our problems. The answers we have found only serve to raise a whole set of new questions. In some ways we feel we are as confused as ever, but we believe we are confused on a higher level and about more important things." - Earl C. Kelley
Valued Contributor
sathersc23
Message 4 of 9 (380 Views)
08-24-2012 11:45 AM in reply to: sathersc23
To pre-empt the next common question (that I asked once myself), there are no "standard radiuses" to fold to or design with, it depends entirely on your tooling and material. If you're doing thin sheet over a break, try 1/16 or 1/32 radius, if you're doing 1.25" steel try 2-3 inches.
Furthermore the k-factor is the ratio of the neutral axis of the bend (grab a mechanics book for that one) from the bend surface across the part thickness.
Sam Sather
CAD Admin/Designer
Inventor 2012
12.0 GB Ram
Windows 7 x64
sinus19
Message 5 of 9 (366 Views)
08-24-2012 12:17 PM in reply to: sathersc23
Oh I see... Well at the shop we have a hydraulic break that uses sharped end dies and when it bends a sheet it leaves a sharp crest on the inside but a round bend on the outside. Where/how can i change the setting for the radius?
sinus19
Message 6 of 9 (365 Views)
08-24-2012 12:21 PM in reply to: sinus19
oh wait i got it! never mind. Thanks guys for the tips. :smileyhappy:
JDMather
Message 7 of 9 (348 Views)
08-24-2012 02:14 PM in reply to: sinus19
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
blair
Message 8 of 9 (339 Views)
08-24-2012 03:43 PM in reply to: JDMather
We had really sharp dies on our hydraulic press in the shop, the damage that can occur when someone wants a sharp inside radius will "cut/score" the material. I have never found this to be a good thing.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.75
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
Valued Mentor
jeanchile
Message 9 of 9 (326 Views)
08-24-2012 09:00 PM in reply to: sinus19
As another comment/side note on this issue, if this is a structural part made from steel the AISC publishes a minimum inside radius for cold bending. Any smaller than this and the part is prone to cracking and yielding. Have no idea if this is what you are doing, just thought I would add my two cents along the lines of what blair was mentioning in hopes that you (or someone else later) doesn't overlook something. Good luck!
Inventor Professional 2013 (SP-2.3), Product Design Suite Ultimate
Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (331.81), Space Pilot Pro (3.16.1)
Laptop: Intel Core i7 3.9GHz, 16.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTX 780 (331.81), SpaceNavigator (3.17.7)
