Inventor General Discussion
Active Member
austonwerner
Message 1 of 8 (263 Views)
Creating a Hole on an Extruded Side
263 Views, 7 Replies
10-29-2013 09:10 AM
I'm making a throttle body spacer in 2013
For some reason I can't get a hole made on the side of the extruded side.
I place a general point on a new 2d sketch and no luck.
Any ideas.
*Expert Elite*
JDMather
Message 2 of 8 (259 Views)
Re: Creating a Hole on an Extruded Side
10-29-2013 09:18 AM in reply to: austonwerner
Can you attach the ipt file (of something similar if proprietary) or at least a picture?
Not sure what a "general point" is, you will probably want a sketch Center Point.
Have you gone through the tutorials?
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
austonwerner
Message 3 of 8 (254 Views)
10-29-2013 09:21 AM in reply to: austonwerner
Active Member
austonwerner
Message 4 of 8 (253 Views)
*Expert Elite*
JDMather
Message 5 of 8 (246 Views)
10-29-2013 09:25 AM in reply to: austonwerner
#1. doesn't look like anything proprietary in that, why not post ipt file?
#2. You can attach images directly here.
Go to the Windows Start globe in lower left corner of screen.
Click on it and the type Snip, select the Snipping tool and use it to snip a screen capture, save and attach here.
*Expert Elite*
Curtis_Waguespack
Message 6 of 8 (241 Views)
10-29-2013 09:33 AM in reply to: austonwerner
Hi  austonwerner,
Are you creating a plane tangent to the curved face as discussed at this link:
http://forums.autodesk.com/t5/Inventor-General/help-placing-a-hole-in-the-outside-of-a-curved-surfac...
If so, then you should be able to sketch on that plane and create the hole center point.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Member
austonwerner
Message 7 of 8 (200 Views)
11-02-2013 12:52 PM in reply to: austonwerner
If I send the file to someone could they put in the desired hole. I can't figure it out for the life of me.
*Expert Elite*
JDMather
Message 8 of 8 (195 Views)
11-02-2013 02:00 PM in reply to: austonwerner
I already did it for you  (see the attachment to post #5).
Simply edit the dimensions to whatever you need.
I recommend you go through these
Announcements
Need installation help?
