Inventor Forum
Creating a flat pattern from a rolled object
4 REPLIES 4
GavinReynolds2021
700 Views, 4 Replies
Hello, Sorry to ask what is probably a daft question but I am having trouble creating a flat pattern from a rolled part. I know I have done this in the past but for the life of me I cant think what I am missing. I am basically using the sheet metal function to print a 1:1 paper template to wrap around a 10" pipe to cut the correct shape to weld the pipe to an unusual object. I have done this in the past joining large pipes at non standard angles. In this case I have to match the 10 inch pipe to the top of a hemisphere at right angles. I drew the pipe, hollowed it. Drew a quadrant of the hemisphere and rotated it as a cut to removed the shape in the 10 in pipe. I created a cut line in the resultant shaped pipe. I have checked my material thickness matches the sheet metal rules yet I still get a message telling me to check that. I dont work with sheet metal functions very often. If someone can point out my mistake I would appreciate it. File is attached. Thank you Gavin
Tags (2)
4 REPLIES 4
Perhaps like this? Last thicken feature is providing rectangular edges of flat pattern.
Walter
Walter Holzwarth
in reply to: GavinReynolds2021
Hi GavinReynolds2012,
There will be a number of way to make the paper wrap around, hopefully this might
be of help. I don't know your shape requirements as i could not see your attached file.
Cheers
Mark
Inventor 2014
Hi Walter,
Thank you for your help. This is a different method than I have used in the past but I was able to modify it to achieve what I needed to do. I have attached the file below. I think you misunderstood my description of the intersection with the hemisphere so I just wanted to show you what I did.
I appreciate the help
Regards
Gavin
Thanks, Gavin. Now I understand better.
Additional note: For obtaining perpendicular edges in the flat pattern, in most cases two intersecting thickens are needed. One inside out, and one outside in.
Walter Holzwarth
