Solved by WHolzwarth. Go to Solution.
Perhaps like this? Last thicken feature is providing rectangular edges of flat pattern.
Walter
Walter Holzwarth
Hi GavinReynolds2012,
There will be a number of way to make the paper wrap around, hopefully this might
be of help. I don't know your shape requirements as i could not see your attached file.
Cheers
Mark
Inventor 2014
Hi Walter,
Thank you for your help. This is a different method than I have used in the past but I was able to modify it to achieve what I needed to do. I have attached the file below. I think you misunderstood my description of the intersection with the hemisphere so I just wanted to show you what I did.
I appreciate the help
Regards
Gavin
Thanks, Gavin. Now I understand better.
Additional note: For obtaining perpendicular edges in the flat pattern, in most cases two intersecting thickens are needed. One inside out, and one outside in.
Walter Holzwarth
