Inventor Forum
Creating a Custom Iproperty
2 REPLIES 2
BP95
428 Views, 2 Replies
Hello, I've created a custom Iproperty and have put it into the Title block of the Drawing. The trouble I'm having though, is that I would like that iproperty to be a default property when I open a new drawing, that way I don't have to go and make a new custom property every single time I make a new drawing. So is there anyway to save an iproperty as a default property for inventor? If you have any solutions or ideas it would be much appreciated. Thank you.
Tags (1)
2 REPLIES 2
mcgyvr
in reply to: BP95
You can just open your template and add the custom field there.. Then each time you start a new part using that template the custom field will be there..
Curtis_Waguespack
in reply to: BP95
Hi BP95,
To follow up on what mcgyvr suggests, there is a bit of trick to doing this if your intent is to pull a model iProperty into the drawing title block:
http://forums.autodesk.com/t5/Autodesk-Inventor/ipt-Custom-iProperties-to-idw-Title-Block/m-p/379641...
I hope this helps.
Curtis
