Brian,
I haven't had time to look into it yet. It might possibly be a Vista
issue it seems? I use a 3rd party licensing solution that MIGHT
have issues. According to Joakim, it crashes IV2010 when the function
to display the registration info is called. There might be some
TypeName "IRx" issues in it too, but it's been a long time since I've
looked at it.
Bob
Brian Ekins (Autodesk) wrote:
> Bob,
> I would be interested in learning why your older program is not working in
> Inventor 2010. Older programs should continue to work, with very few
> exceptions.
> Joakim,
> I wrote a small VBA macro to import coordinates from an Excel sheet and
> create work points. The spreadsheet is the same format as that used by the
> Import Points command. I did limited test but it seems to work ok. One
> limitation is that it doesn't create the work points in a 3D sketch. That's
> a current limitation of the API. You can only create them at the top level.
> The attached file contains the VBA source code. Just copy and paste it into
> a VBA module and run the CreateWorkPointsFromExcel macro.
