Couldn't find it anywhere but, Is it possible to create a drawing parts-list style from a built parts-list in the drawing? Anyone done this?
Cheers for any responses!
Solved by Curtis_Waguespack. Go to Solution.
I'm not really sure what you are asking.. Can you provide more details..maybe some screenshots?
I "think" this is what you are asking for though...
If you have a parts list style that you modified in a drawing and you now wish for that to become your "default" then it "could" be as simple as saving that to the style library via the "save" button in the "styles and standard" section of the "manage" tab
Hi ben_neb43,
I'm a bit unclear about the question as well, but if you're asking about taking a placed, "on-sheet" Parts List that you have edited and applied overrides to (for instance, you've used the Column Chooser to add a new column, etc.), and making that a new Parts List Style, just by pushing a button or selection an option, I do not thing that can be done.
Instead you'll need to create a new Parts List Style and apply those same changes to the new style (or to an existing style). You can right-click on the Parts List and choose Edit Parts List Style to step right into the specific style that you started with before the overrides were applied to the placed Parts List. But then you'd need to make the changes to the style to match the overides.
I hope this helps.
Curtis
Thankyou both for your replies,
Sorry, I was a bit unclear about my question. I was just wondering if it was possible to take a parts list that had been altered on a drawing by, column widths, headings, column chooser etc. and base a style off it.
The reason being that it's a bit awkard and annoying to modify the parts list style in the styles editor, by changing column widths, columns etc. Is there a way to edit the parts-list in the drawing and create the style from it? perhaps using VB or ilogic?
thanks again,
Ben
Gotcha now..
So yes what Curtis said is true.
I'd get used to working with the style editor though.. Its a big part of Inventor and if you aren't familiar with it you should learn now..
I find it very simple to work with.. But I forced myself to play around quite a bit when I first got Inventor because I knew it was important.
