Is it possible to have a View Representation(section view) in an assembly such that a half section view is active, but only some parts should active. ie, i need to show sections of some part and exclude other parts (rest parts should have full view).
Thanks in advance,
Neil George
Solved by salariua. Go to Solution.
I would do it in the drawing.
Right click on the model under your section view "Section Participant / None"
Select the sub-parts of the model in the browser that you need sectioning " Section Participant / Section"
