Inventor General Discussion
Active Member
acet77700
Message 11 of 13 (277 Views)
Re: Create Punch tool in inventor 2013
12-06-2012 05:10 AM in reply to: JDMather
I don't understand what you want,
sorry i'm french and y have not very good english
Member
XXL_darth
Message 12 of 13 (38 Views)
09-08-2014 09:11 AM in reply to: mcgyvr
Hi, I cannot seem to find the way to save this loft into a punch tool, can you help me do this or show me how, I would really apreciate it!!
Employee
johnsonshiue
Message 13 of 13 (31 Views)
09-08-2014 11:45 AM in reply to: XXL_darth
Hi! Punchtool (iFeature) is limited to some sketch-based features not all. Sweep based on 3D sketch path and Loft are among the ones being excluded unfortunately.
For a regular part, you could use a workflow to bypass the restriction. Basically, you make a source feature part. Then derive it as a separate body in the part you want to place the feature. Then use Move Bodies (Direct Edit) command to relocate the feature body to the desirable place. Next, use Combine feature to join or cut it.
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
