Inventor Forum
Create Non-rotating view
2 REPLIES 2
meck
232 Views, 2 Replies
I have a solid body .ipt that I have created an assembly from. Some of the parts in the solid body can rotate which in turn rotates them in the assembly which is great. The problem is I need to create a drawing of the parts of the assembly. If I create a base view of a part that rotates the view rotates also, but I do not want that. Is there a way to create a view that always "looks" at a surface of a part no matter what position it is in? Or maybe some other way around this problem?
Thanks in advance!
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
2 REPLIES 2
bryanthomas
in reply to: meck
After you create the base view of the part RMB and goto rotate. Then select a line to orientate it the way you want. It will then stay in this position regardless of part rotation. I just tested it.
meck
in reply to: bryanthomas
Excellent! Works great!
Now I can remove the code that I used to compensate for it.
Mike Eck
Using Inventor 2018
