Inventor General Discussion
Member
SK83
Message 1 of 4 (413 Views)
Create Mesh Inside Cylinder
413 Views, 3 Replies
04-06-2012 07:10 AM
I'm having difficulty trying to create what could be described as a diamond pattern inside a cylinder. Does anyone have any idea how to achieve this.
Please see picture for an idea of the pattern.
*Expert Elite*
Curtis_Waguespack
Message 2 of 4 (401 Views)
Re: Create Mesh Inside Cylinder
04-06-2012 07:45 AM in reply to: SK83
Hi SK83,
You can use a color style with a transparent property to do this. Here's a link with some more information. Note that Inventor installs with some of these styles (Expanded Metal 01 thru 04).
http://inventortrenches.blogspot.com/2011/04/textures-bump-files-and-ral-colors-for.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Distinguished Mentor
IgorMir
Message 3 of 4 (358 Views)
04-06-2012 05:38 PM in reply to: SK83
Your part should look similar to the one on the attached image after you do what Curtis has suggested.
Best Regards,
Igor.
Web: www.meqc.com.au
paulcasaqua
Message 4 of 4 (349 Views)
04-06-2012 09:51 PM in reply to: SK83
Is any one else having troubles accessing the English website?
Otherwisw how can the Textures be downloaded.Looks great
Cheer
Paul
Need installation help?
