Show only
Search instead for
When I create a new view rep that has parts in subassemblies visibility turned off (from within the top level assembly) then create a LOD from that view - the LOD suppresses the entire subassembly. I then have to go back and unsuppress the parts I want shown. Is this behavior as designed? It would be great if it would truly copy the view as it is to the LOD.
IV 2008
Windows XP pro X64
4GB RAM
NVIDIA Quadro FX 3450/4000 SDI
View-Reps as strictly a visual management tool for either suppressing items
or positional reps. LOD is a memory management tool that doesn't load the
deselected items into memory.
Dell Precision 690
Dual Quad Core E5320 @ 1.86GHz
4Gb DDR SDRam - 667 Mhz, ECC
SAS 146Gb - 15k rpm
Quadro FX3500 256Mb - Driver: 169.61 Bios: 5.71.22.55.08
XP Pro Sp2 - AIP 2008sp2 - D3D
Space Explorer USB 3.6.4 wrote in message news:5919970@discussion.autodesk.com...
IV 2008
Windows XP pro X64
4GB RAM
I understand this. This does not answer my question. Why does Inventor suppress the entire subassembly when I create a LOD from the view rep instead of just what was turned off inside the subassembly?
Message was edited by: crekyman
