I'd like to add a sketch to my drawing - a sketch that is independent of any other views. Is it possible to make this sketch have a scale associated with it instead of being 1:1?
Right now I am just overriding all of my dimensions.
Solved by Curtis_Waguespack. Go to Solution.
Hi schnautza,
If you create your sketch as a Draft View, you can scale it as needed.
I hope this helps.
Curtis
