Rotate the assembly view so you are looking more or less normal to the
assembly XY plane.
Create Component. Clear the check box on "Constrain sketch...". Pick the
nearest face of Part1 or, probably the safer bet, just drop it in space
without picking a face.
Make the new part origin planes visible and return to assembly mode.
Since the face you want Part2 to mate to is in the assembly XZ plane,
constrain the new part XZ plane flush with that face. Constrain, as wanted,
the other new part planes to Part1 making sure the plane normals (the arrow
you see when constraining) is aligned with the assembly coordinate system.
Now edit the new part and define your first sketch on the appropriate new part
origin plane, depending on whether the first feature will be normal to or
along the existing part face.
If you are constraining the new part to an irregular shape part: When you
create the new part constrain the part origin planes flush with the assembly
origin planes and create the first sketch plane (adaptive) by picking the
desired existing part face.
I have a part template that has the part coordinate system vectors from origin
sketched in. You might try that.
Hope this is what you are after and will help get you started.
"Alex123"
wrote in message
news:f14f02f.3@WebX.maYIadrTaRb...
You are not missing the point at all. But no matter what surfaces I pick, the
part in the Assy and the same part by itself are not orientated the same. You
wrote "If you do not orient the part to the assembly the coord system
orientations will differ between assembly and part". This is exactly my
problem!
But how did I not orient the part to the assembly? Here is what I am doing.
Create Part in Place. Select Sketch Plane. I am going to Assy Origin and
picking YZ Plane. Now I must select a Sketch Plane to start my part. I am
going to Part Origin and picking YZ Plane again. I did this to try to use the
same exact plane.
I look at the part I just made in Assy, than I go to Part mode and it is
orientated different. I am pulling my hair out.
Can you open my post and look at it or walk me thru it step by step. Something
is wrong?
