I'm currently analysing a turret shafts with shell elements in inventor professional 2013. I was wondering if i could make a graph of the stresses that occur on the different angels of the shaft. First i tought i could use the stresses that occur on the diferend nodes and create a graph, but inventor does not show any nodes. so i thought i could use probes on different points of the shaft en create a graph with probe results.
to use probes and create all the coordinates by hand would take days. so i was wondering if i could write a program (API) where the probe will be inserted automatically to the coordinates.
I was also wondering if i could write the coordinates in Excel and use these as paramaters in Inventor.
the coordinates X,Y en Z will be the input and the value of the probe will be the output.
can somewone help me out, and if it is possible in which program could i write the code?
regards, Rick
