To increase the speed of production, I like to generate idws of flat patterns from assembly. The following iLogic rule work fine inside a metal sheet (I had to create flat pattern before run this rule).
Imports Inventor.ViewOrientationTypeEnum Imports Inventor.DrawingViewStyleEnum Dim oDrawingDoc As DrawingDocument Dim oPartDoc As Document Dim oSheet As sheet Dim oTG As TransientGeometry Dim oView1 As DrawingView Dim oOptions As NameValueMap oPartDoc = ThisApplication.ActiveDocument oDrawingDoc = ThisApplication.documents.Add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2011\Templates\Standard.IDW", True) oSheet = oDrawingDoc.Sheets.Item(1) oOptions = ThisApplication.TransientObjects.CreateNameValueMap oOptions.Add("SheetMetalFoldedModel", False) oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(15#, 15#) oView1 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, 1/5#, kDefaultViewOrientation, kHiddenLineDrawingViewStyle, , , oOptions)
But from an assembly there are some problem ( firstable I'm not an expert of vba and ilogic)
Imports Inventor.ViewOrientationTypeEnum Imports Inventor.DrawingViewStyleEnum fmgr = ThisApplication.Filemanager For Each file In fmgr.files doc = ThisApplication.Documents.ItemByName (file.fullfileName) compdef = doc.ComponentDefinition ' For each assembly or subassembly 'If (doc.documenttype = 12291) Then For Each occ In compdef.Occurrences ' For sheet metal or part If (occ.definition.type =83886592) Then ' If (occ.definition.Subtype ="{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then Dim oDrawingDoc As DrawingDocument Dim oPartDoc As Document Dim oSheet As sheet Dim oTG As TransientGeometry Dim oView1 As DrawingView Dim oOptions As NameValueMap oPartDoc = ThisApplication.ActiveDocument oDrawingDoc = ThisApplication.documents.Add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2011\Templates\Standard.IDW", True) oSheet = oDrawingDoc.Sheets.Item(1) oOptions = ThisApplication.TransientObjects.CreateNameValueMap oOptions.Add("SheetMetalFoldedModel", False) oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(15#, 15#) oView1 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint1, 1/5#, kDefaultViewOrientation, kHiddenLineDrawingViewStyle, , , oOptions) ' MessageBox.Show("test1") ' Else ' MessageBox.Show("test2") End If Next occ 'End If Next file
Can someone help me?
i guess you have to open sheet metal part before create its drawing document.
