Inventor Forum
Create dimension angle in dwg drawing
15 REPLIES 15
Message 1 of 16
2shaen
10872 Views, 15 Replies
i want to ask how to make the size for the angle in the distance between holes. i use the autodesk inventor 2013, please help step by step. i attach an example like this.
Tags (1)
15 REPLIES 15
Message 2 of 16
2shaen
in reply to: 2shaen
I want to ask how to make the size for the angle in the distance between holes. I use the autodesk inventor 2013, please help step by step. I attach an example like this.
Tags (1)
Message 3 of 16
jyothissurendran
in reply to: 2shaen
I am not i understand you correctly or not.
If you want to show the dimension overthere, i think the available options is u can use constuction lines.
If you need to create the  holes as per the dimension? go to sketch and use circular pattern.
Jyothis Surendran
Autodesk Autocad 2014 & Inventor Professional Suite 2010
Windows 10
Message 4 of 16
2shaen
in reply to: jyothissurendran
I've made a 3D part, but I want to make a 2D drawing. When creating 2D I want to add a label that the distance between the hole using the angle to mm or inchi.how i can create this?
Message 5 of 16
jyothissurendran
in reply to: 2shaen
  • Create  Center points for the circles by using sketch option.
  •  Exit sketch
  •  Then select the dimension tool pick the three center points defined first
see attached for more clear ....
Hopes this will help u ....
Accept as solution, If u foud so....
Jyothis Surendran
Windows 10
Tags (1)
Message 6 of 16
SBix26
in reply to: 2shaen
How much Inventor training and/or experience do you have?  Can you post a screen shot of the dimension as it looks now?  I don't know what part of the dimension appearance is causing you a problem, so no idea how to advise you.
Message 7 of 16
robsman
well, it's even easier than that: no need to create a sketch and center points. you can snap to the centers of the holes directly. by the way ; this works in model sketches also.
cheers
rob
Message 8 of 16
john.laidler
in reply to: 2shaen
Are you asking how to create this as a 'sketch'?  If so, you'll need to utilize construction lines to dimension the angle.
John Laidler
AutoCAD, Inventor and Vault
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 9 of 16
ampster402
in reply to: 2shaen
Message 10 of 16
2shaen
I've tried but could not. I attach the 3D part and DWG. and drawing what I want, maybe you can help me ...
Message 11 of 16
2shaen
in reply to: john.laidler
no, this is in dwg drawing. can you help me?
Message 12 of 16
2shaen
in reply to: SBix26
Message 13 of 16
okaleja
in reply to: 2shaen
Please see the attached video which shows how to create the angular dimension.
Hope this helps,
Oto Kaleja,
Oto Kaleja
Software Engineer
Message 14 of 16
2shaen
in reply to: okaleja
hello,
Sorry i can't open or download your the video
Message 15 of 16
okaleja
in reply to: 2shaen
That should be easy:
1. Click on the link above with the name of the zip file
2. Download/Save the file on the local machine
3. Open it by double clicking, associated application should open
4. Inside the zip there is a video file, double click on it to watch the video
Oto Kaleja
Oto Kaleja
Software Engineer
Message 16 of 16
2shaen
thanks it's work....
