Another approach might be to simplify your assembly by selecting the target
component, right mouse click and select Isolate. Then select Create
Component and try picking the face. You may have other geometry within your
assembly that is confusing the selection process.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:5983743@discussion.autodesk.com...
the issue is really with when I select a face to sketch on. It doesn't open
the sketch on the face but a plane 90 degrees to the face.
