Inventor Forum
Create Block description
3 REPLIES 3
karthur1
261 Views, 3 Replies
When I create a sketch block, there is a description area.  After the block is saved, how can I see this information again?  If I right click on the block in the browser, I cant find it anywhere.
3 REPLIES 3
Hi karthur1,
Edit the sketch block and then right-click anywhere that is not on the sketch entities, and then choose Block Properties.
I hope this helps.
Curtis
JBerns
in reply to: karthur1
I realize this is a very old post, but my coworker just asked the same question today regarding sketch block descriptions.
Generally, I use a descriptive block name so that I do not have to use a description.
But why bury the information so that it is difficult to view.
Would it make sense to see the description if you hover over the block in the browser?
Time for an IdeaStation suggestion.
https://forums.autodesk.com/t5/inventor-ideas/display-sketch-block-descriptions-when-you-hover-over-...
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
karthur1
I like it.  Voted.
