I have two .dwg files that represent two different surfaces. I woudl like to import each .dwg file into Inventor, then creat a solid with the original surfaces serving as the top and bottom. How can I do this? I can send the .dwg files if necessary.
Create a new part and in then create a new sketch. Import the dwg file into the sketch. Finish the sketch.
Create a work plane offset from the first sketch plane whatever distance you'll want the finished solid height to be.
Create a new sketch on that new work plane and import the second dwg file. Finish the sketch.
Now, create a loft between the two sketches and you have a solid with each of your dwg files on the ends of the solid.
Attach the files if you need help.
Have you tried creating an intermediate sketch and extruding to the surfaces?
See attached
I haven't tried anything. I'm a new Inventor user. I couldn't find anything online that talked about doing something like this in Inventor.
Here's a simple video explaining how to create a loft. In your case, instead of actually drawing your lines and circles in the sketch, you're going to insert the ACAD dwg into the sketch.
@ahammack wrote:I haven't tried anything. I'm a new Inventor user.
I think most experienced Inventor users would suggest that you NOT try, as a beginner, to reuse AutoCAD geometry in Inventor.
There is nothing really wrong with it, and I'm sure you are more comfortable with AutoCAD - but take my word having taught hundreds (thousands?) of former AutoCAD users - start from scratch in Inventor unless the AutoCAD geometry is something particularly complex (I'm thinking of a Maple Tree Leaf as an example someone wanted to emboss that would have been easier to import the existing AutoCAD geometry). If it is simple, simply do it over.
If you are experienced in Inventor - then simply import the AutoCAD geometry.
The CADWhisperer YouTube Channel
@Anonymous wrote:If it is simple, simply do it over.If you are experienced in Inventor - then simply import the AutoCAD geometry.
Absolutely! Doing it over is always better.
Unfortunately, the surfaces I am trying to import are complex - one of them represents a river bed. I tried uploading the files, but they are too large to upload to the forum. I could import the points (there are hundreds) and create new surfaces that way, but I couldn't find anything online about how to do that, either.
@ahammack wrote:...one of them represents a river bed...
Maybe it would be best if you explained your overall goal. I assume you're not designing the river bed , so is this going to be used as a reference for a structure frame, etc.? Or are you possibly attempting to use Inventor for some purpose other than mechanical design?
If you provide the big picture, I'm sure someone will be able to provide some direction.
I hope this helps.
Curtis
@ahammack wrote:I tried uploading the files, but they are too large to upload to the forum.
The file size limit is much larger over here http://www.augi.com
In Windows Explorer right click on the file and select Send to Compressed (zipped) Folder and then attach the resulting *.zip file.
