just wondering if it's possible to create a derived part using only some of the features of the base components
i.e. I've got a funny shaped part with a bunch of holes in it, and I need another part with exactly the same shape but totally different holes (location and size)
I know you can do this with the different solids in the part (only use some of the solids) but I haven't been able to figure it out with features, if it's possible at all.
I could probably create one base part (just the shape) and derive both parts from that, but then I've got a part lying around doing jack.
Solved by PaulMunford. Go to Solution.
The derived comman derives the body(ies) from the part, not the features which creates the body. You can try to insert your part into an assembly and derive that assembly. In the derived assembly dialog select the Options tab and enable Hole Patching - either patch All holes or based on perimeter. This will derive the assembly including your part body and it also removes the holes from the part. You can edit the derived body after this - add new holes to different place.
Csaba
Of course the best way would have been to have only the common geometry in the master original and then Derive as needed.
Another option in addition to those already described is to Derive and then Delete Face with Heal option to remove unwanted holes.
good work around I suppose, and I'll use it, but it would be nice to be able to suppress certain features in the derived part.
I have come across with the same issue and to resolve it I used 2 different workarounds:
With Inventor 2022, your problem may be solved. Model States allows both (or all twenty, for example) variants to be defined in one part file. You can add the different model states to assemblies and to drawings as you wish.
I haven't explored all the implications and possibilities of Model States, but it makes close variants such as you're describing a simpler management task. One of the most common "identical but different" modeling tasks in my career was mirrored parts. Now it's simply done in one file and that's all there is to it (in most cases).
Sam B
Inventor Pro 2022.0.1 | Windows 10 Home 20H2
LinkedIn
