I am wondering if it is possible to easily create simple dimensional conditions, which - if they are not fulfilled - trigger a warning. Let me explain: a certain dimension of my part must not exceed some limit, but otherwise its value is not important, it is not a driving dimension. However it depends on other, driving dimensions, which I am changing during my design process. Is it possible to get an automatic warning if this dimension exceeds the predefined limit?
Daniel
Solved by admaiora. Go to Solution.
Maybe Autolimits could helps you
p.s. if you don't see the tab, just tool>add-in> and load Autolimits from menu
Admaiora
