Inventor Forum
Crazy Question? Adaptivity
10 REPLIES 10
Message 1 of 11
SRayC
152 Views, 10 Replies
I am little embarassed to ask such a question, but if you don't ask you won't get an answer. Here goes.
I am working in sheet metal (panel builder). I want to create a group of models of components that are mounted on and into sheet steel panels. These components will have portions that would need to extrude through the panel. (Now the question) Is there anyway in the assembly mode that when placing these components on the panel that setting some sort of adaptivity that it would automatically cut the material out of the sheet steel panel in the area of the interference? Ultimate adaptivity!! This would eliminate the need to punch the panel first and then place the device.
What do you think.
Ray C.
10 REPLIES 10
Message 2 of 11
in reply to: SRayC
assemble the components inside the assembly. Edit
the panel from inside the assembly, start a sketch on the face where you want to
make the cut and then project the profile of the components to the sketch. Then
just extrude as a cut.
I
What do you think.
Ray C.
Message 3 of 11
SRayC
in reply to: SRayC
Thanks Donovan,
That works pretty good. Not quite automatic but its a start.
I have another question. I can't seem to find a way to save the modified steel part as a new file. Any suggestions.
Ray C.
Message 4 of 11
in reply to: SRayC
save a copy of the modification? or save a copy of
the flat pattern?
Donovan,
Ray C.
Message 5 of 11
SRayC
in reply to: SRayC
Save a copy of the modification as a new part file with a different name. I will create the flat latter.
Message 6 of 11
in reply to: SRayC
dropdown menu file>save copy as> this is
where you can create new copies of an existing file to modify. It's also where
you would save a part or assembly out into another file
format.
Save
Message 7 of 11
SRayC
in reply to: SRayC
This seems to only allow me to save the assembly of the modified steel part and component as a new iam file. I need to save the modified steel part only as a new ipt file.
Message 8 of 11
in reply to: SRayC
save copy as inside the ipt
This
new ipt file.
Message 9 of 11
SRayC
in reply to: SRayC
I am having trouble with this one. The steel part is modified with an assembly feature(extruded cutout). According to the documentation assembly features do not affect the part model. I have tried highlighting the steel part and then save copy as but the part does not include the new cutout. I need to find a way to modify a part in the assembly and then save the modified part as new part.
I may repost with my new issue.
Message 10 of 11
in reply to: SRayC
Assembly features will not affect the part
model(s), but adaptive cut-extrusions will.
And if you don't Save-Copy-As but Derive the part,
a
ny changes in the original part will be
reflected in the "NewPart.ipt"
I
part.
Message 11 of 11
SRayC
in reply to: SRayC
Thanks! The Derived Part worked well. But how do you make the extrusion adaptive. I was able to make the part with the assembly extrusion adaptive but that did nothing to the part.
