style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"srayc" <I
href="mailto:raycordery@eaton.com">raycordery@eaton.com> wrote in
message
href="news:f197ac1.-1@WebX.maYIadrTaRb">news:f197ac1.-1@WebX.maYIadrTaRb...
am little embarassed to ask such a question, but if you don't ask you won't
get an answer. Here goes.
I am working in sheet metal (panel builder). I
want to create a group of models of components that are mounted on and into
sheet steel panels. These components will have portions that would need to
extrude through the panel. (Now the question) Is there anyway in the assembly
mode that when placing these components on the panel that setting some sort of
adaptivity that it would automatically cut the material out of the sheet steel
panel in the area of the interference? Ultimate adaptivity!! This would
eliminate the need to punch the panel first and then place the device.
What do you think.
Ray C.
"srayc" <Thanks
message
href="news:f197ac1.1@WebX.maYIadrTaRb">news:f197ac1.1@WebX.maYIadrTaRb...
Donovan,
That works pretty good. Not quite automatic but its a start.
I have another question. I can't seem to find a way to save the modified
steel part as a new file. Any suggestions.
Ray C.
"srayc" <Save
message
href="news:f197ac1.3@WebX.maYIadrTaRb">news:f197ac1.3@WebX.maYIadrTaRb...
a copy of the modification as a new part file with a different name. I will
create the flat latter.
"srayc" <This
message
href="news:f197ac1.5@WebX.maYIadrTaRb">news:f197ac1.5@WebX.maYIadrTaRb...
seems to only allow me to save the assembly of the modified steel part and
component as a new iam file. I need to save the modified steel part only as a
new ipt file.
"srayc" <I
message
href="news:f197ac1.7@WebX.maYIadrTaRb">news:f197ac1.7@WebX.maYIadrTaRb...
am having trouble with this one. The steel part is modified with an assembly
feature(extruded cutout). According to the documentation assembly features do
not affect the part model. I have tried highlighting the steel part and then
save copy as but the part does not include the new cutout. I need to find a
way to modify a part in the assembly and then save the modified part as new
part.
I may repost with my new issue.
