I'm working on a project that hasn't required that much SM in R8, did you
guys fix the touch-me-not complex when you were working on the lofts, maybe
... well ... except for this case that works on one side maybe?
~Larry
"Loren Jahraus (Autodesk)" wrote in message
news:982E9D61C70F3BE331A966B361DA1172@in.WebX.maYIadrTaRb...
> For some reason it is getting confused when the offset is towards the
> outside. If you change the radius to .25 + Thickness and offset it towards
> the inside, you can increase the angle until it touches.
> Loren Jahraus
> Autodesk Inventor Workflow Team
> "Kent Keller" wrote in message
> news:27C67084C732992D6C1462BB92E30E54@in.WebX.maYIadrTaRb...
> > I posted a file to IVCF that is just a simple contour flange. Can
anyone
> figure out why I
> > can't increase the angle on the loop any farther? I know I can do this
> other ways, but
> > it sure seems to me this should work?
> > Kent
> > Assistant Moderator
> > Autodesk Discussion Forum Moderator Program
