Good morning, as you can restart the "clock" of views and details of IDW, to start again from the lestra "A" in the same drawing?
Thank you very much!
Solved by brendan.henderson. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Yes, from the "View Identifier" manually by editing the name, it's like I usually do, either found as restarting the "counter" so I was consulting, I thought you had some way. Thank you very much!
