Inventor Forum
Could not activate Rip Command
3 REPLIES 3
RobJV
458 Views, 3 Replies
After deleting some rips and corner seams on my model, I can no longer create rips, unfolds, or refolds.  They all come up with the same message as shown in attached picture.  Any ideas?
I have already shut down and restarted.
Rob
3 REPLIES 3
SBix26
in reply to: RobJV
Sounds as if a face got removed so you now have only a surface model.  But I do remember getting a message like this in the last few weeks, with a file someone posted on this forum, where the body was reported as a solid in the browser, but still gave this message when trying to apply a rip.  Seems as if it was somehow corrupted.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
JDMather
in reply to: SBix26
How did you delete these features? Did you use the Delete Face command?
RobJV
in reply to: JDMather
Hi JD,
No delete face command used.
It is definitely a solid with volume and mass.  It contains a derived part but do not think that has anything to do with it. Interesting that somebody else had a similar issue.  I have even tried deleting everything all the way up to the derived part and recreating the extrusion, shell, and then ripping but same error.
-Must be corrupted somehow.
I will probably have to create a new part from scratch.
Rob
