I need to copy only the section views to other sheets & I couldn't find how to do this. Can anyone suggest the procedure?
Sudhi
Solved by JDMather. Go to Solution.
Do you want to copy or simply move?
To move click and drag the section node in the browser to the second sheet.
To copy first create a duplicate section in first sheet and then click and drag as above instruction.
When you do this click and drag you will see a black bar in the browser for the second sheet when done correctly.
