Inventor Forum
Copying parts w constraints
4 REPLIES 4
309 Views, 4 Replies
Is there a way to copy multiple parts that are constrained to each other and keep the constraints?.
I do not want to create a sub assembly and then insert mulitple times.
4 REPLIES 4
A workaround...
demote them to a sub..add as may times as you want
then promote the subs back to the top level.  They will keep their
constraints to one another but not to any external objects.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Is
the constraints?.
mulitple times.
Only problem is when you try to promote more than 1 sub back IV 5.3 & 6 crash. If I do one at a time the other placed assemblies go poof and are gone.
same here.. hmm.. I haven't done this in a
while.  Guess it got broken.  Sorry it didn't work..
Sean Dotson, PE
...sleep is for the
weak..
Only
gone.
It's not exactly what you want, but you could
select the part before you select it, select infer Imate, and then copy the
parts out.  That way you're keeping the constraints, unfortunately
they're not constrained to each other.
Joe Bartels
Is
the constraints?.
mulitple times.
