Hi all
I recently started working on Inventor 2013 and I'm trying to copy a drawing view in order to place it on another sheet. Unfortunatly I see no copy option. Am I doing sth wrong or it's due to the changes in the version?
Were you able to do it in 2012 or previous versions and the same method you used in the past isn't working in 2013?
I did use it on 2011. I was clicking on a view to mark it and was able to copy it and paste it to another drawing file or another sheet. On 2013 I can only copy an entire sheet but not a view from it.
Got it! The views can still be copied but it's mandatory to select the base view and copy it along with all dependant to it.
Works here, selecting the view either in canvas or from the browser. Unless I'm not understanding what you're trying to do.
I'm trying to do exactly the same but unless you select the base view you can't copy. It wasn't so in 2011 if I'm not mistaken
I'm not able to copy section views or detail views but can copy any projected or aux views.
I have to copy the view that the section / detail is created from as well as the section / detail to copy them.
Are you wanting a second copy of the view on another sheet, or do you want to move the existing view to another sheet? If the latter, no copying needed; just use the browser and drag the view from one sheet to another. If the former, then as rdyson points out, a projected view can be copied. If section or detail, not possible (why, Autodesk?).
Best workaround I can think of is to create a duplicate view on the first sheet, so you can see all the annotations on the original, then move it to another sheet.
