Inventor General Discussion
*Expert Elite*
karthur1
Message 1 of 3 (197 Views)
Accepted Solution
Copy view / Replace model Reference
197 Views, 2 Replies
06-12-2012 09:29 AM
One of the new features in 2013 is the ability to copy a view that is on the idw.  Is there a way to copy/paste a view, then replace the reference of ONLY the part in the view that was just copied?
What I have is two parts. For simplicity, just imagine both as a square plate.  One has a hole in it, one doesnt.  I have already dimensioned the square plate. Now I copy the view and paste it back on the sheet.  I want to replace the reference of the one I just copied and change the reference to the part with the hole.  If I use replace model reference command, it will replace both references, which is what I dont want.
Just a wish I guess, but the only way I can do this now it to place the second part on the sheet and start dimensioning it.  Seems like a waste when we almost have the tools to quickly complete this.
Kirk
This is a pure guess as I haven't used this feature.
It is an awkward workaround if it works at all, but can you copy the view to a new drawing perform the replace there and then copy back to the original.
Maybe worth a try.
*Expert Elite*
harco
Message 2 of 3 (192 Views)
Re: Copy view / Replace model Reference
06-12-2012 10:21 AM in reply to: karthur1
Maybe worth a try.
Distinguished Mentor
pauldoubet
Message 3 of 3 (188 Views)
06-12-2012 10:25 AM in reply to: harco
harco is correct, you can do this using a new dwg/idw file. I have done this as it is the only work around that I know of and it works fine, just a few extra mouse clicks.
Hope this helps, Paul
Post to the Community
New Post
Need installation help?
