Inventor Forum
Copy section view to another sheet
15 REPLIES 15
Message 1 of 16
digger19
21886 Views, 15 Replies
Can you place a top view and then create section views on this sheet and then take these section views and copy to another sheet and stay associative to any changes?
Inv 11 sp1
15 REPLIES 15
Message 2 of 16
JDMather
in reply to: digger19
Yes.
Message 3 of 16
digger19
in reply to: JDMather
Can you tell me the process? I am not getting a copy or move option?
Thx
Message 4 of 16
SBix26
You can move a view from one sheet to another, by dragging in the browser, and this will maintain links to the parent view.  I don't know of any way to copy views, but I'm still learning.
I don't think it matters in this case, but do you mean Inventor 11 (five years old now) or Inventor 2011?
Message 5 of 16
PaulMunford
in reply to: SBix26
To copy a view you need to slect the perant view as well.
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 6 of 16
luiww
in reply to: PaulMunford
Please see if the attached example is what you want.
Message 7 of 16
in reply to: luiww
I had the same problem until I realized that you had to grab the view in the browser bar (Mine is on the left) and drag it from there into the page I wanted it on... before I kept trying to grab the actual view and drag it, which didn't work so well.  Hope that makes things a little more clear for somebody out there, I know it would have saved me some time!
Tags (1)
Message 8 of 16
evinne
yes, thanx, this tip was useful ...to complement it ...you can suppress the parent if it unnecessary in the new drawing, if you want to copy just the section view...COPY won't work separately just for the section view
Message 9 of 16
jeffrey.jansenUCRHS
in reply to: luiww
I am having some problems getting a section view placed on a different sheet. I checked your example and that is indeed what I want.
I am using Inventor 2019, is there someone who can elaborate on the process of placing a view on one sheet, make a section of this view and place the new view on a different sheet.
Message 10 of 16
Place the base view, create the section view as always.
Find the new section view in the browser pane, then click-drag it (in the browser) to the destination sheet and drop it there.  That's it.
Sam B
Inventor Pro 2020.0.1 | Windows 7 SP1
LinkedIn
Message 11 of 16
johnsonshiue
in reply to: SBix26
Hi! Yes, Sam is right. Make sure the current sheet containing the section view is active.
Many thanks!
Software Test Engineer
Message 12 of 16
Ed.Jobe
in reply to: johnsonshiue
Hi @johnsonshiue . Is it possible to put the section view in another dwg file?
Ed
How to post your code.
Message 13 of 16
johnsonshiue
in reply to: Ed.Jobe
Hi Ed,
Yes, you can move one view from one sheet to another. You need to do that in the browser by dragging the view.
Many thanks!
Message 14 of 16
Ed.Jobe
I meant, not to a "sheet" in the same dwg file, but another dwg. What I'm doing now is simulating the section view arrows by using a symbol with a view number and dwg callout on a base view. Then in the other dwg, placing a base view and section view and then suppressing the base view.
I don't see a way to drag the section view to another file.
Ed
Message 15 of 16
johnsonshiue
Hi Ed,
No, unfortunately. The closest workflow is to copy the base view and the section view to another drawing. Then suppress the base view there.
Many thanks!
Message 16 of 16
samuele.dalmaso
in reply to: SBix26
this changed my life 😁
MAny thanks
