Hey All! I am now starting to try out Inventor 2012 Professional.
I was trying to copy a fancy polyline from ACAD2011 into a 2D sketch in Inventor 2012. I obtained the polyline by using a raster to vector program. It is a closed polyline that easily extrudes etc in AutoCAD 2011.
However, when I copy the polyline and then try to paste in Inventor, a bunch of points shows up all over (inside, around , far away from) the polyline curve. I only want the curve to show. Please help me figure out how to get rid of the points ( are they arc centre points? How do I turn them off?
Can you attach the original dwg file here?
The points appear to be arc centers - and therefore simply ignore.
You could toggle them from Points to Centerpoints, but not sure why you would bother.
You could make them much smaller going to Tools>Application Options>General tab reducing Annotation Scale - but I don't think I would do that either.
Hi JD,
Merci for the guidance. See attached the original dwg file. I want to be able to use the shape to emboss a name plate per se. When I try to emboss, the program says the gemoetry is not unadaptive.
