Hi James,
I was able to see the issue in your posted block, once I changed it to the points it stopped having the issue.
Not sure what is processed differently.
Points and construction lines should behave the same in theory, but I know that the points do not seem to flip around they maintain the shape during copy and paste.
Try using the Points instead and run it through your copy/paste macro, just to test it out and for a fair comparison.
James
You must of misunderstood I put the construction lines in after the issue it works fine so far but yes points would do the same.
Thanks for the reply James...
No problem James,
I Definitely misunderstood your post back the first time. (I didn't think I saw construction lines in the part you posted).
Keep an eye on it and if does the same thing with either method, let us know.
James
James,
It did not provide me with any new insight.
I have not been able to get it to fail on my system with your part file.
Do you have a different workflow than highlight RMC copy RMC Paste?
Thank you.
I don't want to sound rude but it may.
Have you been reading any of the post?
