Inventor Forum
Copy Paste, Only in Inventor
26 REPLIES 26
Message 1 of 27
jletcher
939 Views, 26 Replies
Copy
Paste
Enough said............
26 REPLIES 26
Message 21 of 27
jletcher
in reply to: bob_holland
Here...
Message 22 of 27
jalger
in reply to: jletcher
Hi James,
I was able to see the issue in your posted block, once I changed it to the points it stopped having the issue.
Not sure what is processed differently.
Points and construction lines should behave the same in theory, but I know that the points do not seem to flip around they maintain the shape during copy and paste.
Try using the Points instead and run it through your copy/paste macro,  just to test it out and for a fair comparison.
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
Message 23 of 27
jletcher
in reply to: jalger
You must of misunderstood I put the construction lines in after the issue it works fine so far but yes points would do the same.
Thanks for the reply James...
Message 24 of 27
jalger
No problem James,
I Definitely misunderstood your post back the first time. (I didn't think I saw construction lines in the part you posted).
Keep an eye on it and if does the same thing with either method, let us know.
James
James Alger
Work:
1tb SSD, 64GB RAM
Message 25 of 27
jletcher
What did you come up with of the report Bob?
 Video card wrong color?
Message 26 of 27
bob_holland
James,
It did not provide me with any new insight.
I have not been able to get it to fail on my system with your part file.
Do you have a different workflow than highlight RMC copy RMC Paste?
Thank you.
Bob Holland
Autodesk Product Support
Message 27 of 27
jletcher
I don't want to sound rude but it may.
 Have you been reading any of the post?
