Inventor General Discussion
Distinguished Contributor
Anthony
Message 1 of 6 (341 Views)
copy multiple objects
341 Views, 5 Replies
01-23-2013 04:17 AM
Is there a way to allow Inventor 2013 to copy multiple objects when executing the 'copy' command ? Similar to in AutoCAD where you can continue to copy objects in multiple instances instead of it terminated after a single copy ? Thanks
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
Distinguished Mentor
john.retzlaff
Message 2 of 6 (330 Views)
Re: copy multiple objects
01-23-2013 05:31 AM in reply to: Anthony
Hold shift when selecting?
John Retzlaff
*Pro
sbixler
Message 3 of 6 (325 Views)
01-23-2013 05:46 AM in reply to: Anthony
You haven't really given us enough information to be helpful, although John's reply might be exactly what you need.  The answer will be different depending on what the objects are that you are trying to copy.  Are you trying to copy components in an assembly?  Sketch elements in a part sketch?  Views in a drawing?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Anthony
Message 4 of 6 (320 Views)
01-23-2013 05:51 AM in reply to: sbixler
Thank you for your response. To clarify, I am copying components in an assembly using the simple 'copy' command from the drop down menu which is available when right click on the component to copy, thanks
*Pro
sbixler
Message 5 of 6 (305 Views)
01-23-2013 08:31 AM in reply to: Anthony
Ctrl-click to multi-select, then copy.
Sam B
JDMather
Message 6 of 6 (298 Views)
01-23-2013 08:51 AM in reply to: sbixler
or
Ctrl click mutliple
or
Shift click first and last (all in between will be selected)
then click and drag one of the part icons into the graphics window and all will be copied.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
