Inventor Forum
Copy Model iProperties
9 REPLIES 9
Message 1 of 10
drguitarum2005
423 Views, 9 Replies
In my drawing template, I went into Document Settings and enabled "copy model iproperties" so my "Title" from my .iam to my document. That way, I set my drawing title in the assembly, and have my drawing reflect the same title from it's own iProperties.
The problem is, the copy operation doesn't seem to take by default. I can do into document settings on a new drawing and see everything is checked, but no properties have been copied. Only when I uncheck the box then recheck it does it copy the properties. Is this a bug? Thanks,
9 REPLIES 9
Message 3 of 10
drguitarum2005
in reply to: cbenner
I'm sorry, Inventor Professional 2014 SP1 v. 18.1.22200.0000 with Update 1 (DL22436654)
Message 4 of 10
blair
in reply to: drguitarum2005
Some items in the Template file can't have information in them until they are actually used. I've run into this before with prefilled text boxes within the Template.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 5 of 10
drguitarum2005
in reply to: blair
Hopefully that isn't the case as it defeats the purpose of "copy model iProperties" really...
Any way of running some iLogic code to force that function to run or refresh?
Message 6 of 10
blair
Some fields are populated when new file is created from the template and others when the "Save" function is run for the first time.
Delta Tau Chi ΔΤΧ
Message 7 of 10
drguitarum2005
in reply to: blair
The weird part is neither new template NOR save will copy the properties. I have to go in and uncheck the box, then recheck and press OK then it will copy.
Message 8 of 10
I think I figured out that if the model iProperties were EMPTY when I created the drawing, I have to manually go and uncheck and recheck the option in the drawing. If I populate the model iProperties and THEN create the drawing, everything works as it should. I can handle that.
To make it idiot proof though for everyone else, is there a way, via iLogic, to sort of "re-initiate" that option and trigger it on save so it'll grab the properties again?
Message 9 of 10
mcgyvr
Just pointing this out.. but if this is to fill out the titleblock there is NO need to use the copy model properties functionality.. You can simply have the titeblock look at the iproperties of the part or assy placed in the base view
None of my idw file iprops have any of that information in them..and the titleblock just pulls the description and part number from the ipt/iam files iprops.
Message 10 of 10
drguitarum2005
in reply to: mcgyvr
Understood. The reason I do it this way is because if I have a weldment with more than one part (which 99% of my models are), I put the assembly information on page 1 and pages 2-x have cut sheets of the individual components. Pulling the part iProperties would mean I'd need to type in the same "Title" and "Subject" (we use two-line titles/descriptions) on each of x parts. By copying it from the assembly and displaying that on each sheet, I only have to do it once: on the main assembly.
