I created an iLogic Form (and some code) in my Inventor drawing template. Now I want to copy this objects by a vb.net script to other drawings. The copy funktion for the iLogic code and the triggers is working fine. But how to copy the Form?
Has anybody an idea?
Solved by stefan.haseborg. Go to Solution.
Solved by VdVeek. Go to Solution.
Solved by salariua. Go to Solution.
I would look into code injector. Have you condered having the rules and forms on external path maybe.
The code injector is a great project an helps me a lot. But this is only for the iLogic code and the triggers and not for the Forms.
Yes, I agree so that's why I asked you if you can have the form as external. Would that be an option in your case?
Sorry, misunderstand the question...
It could be a way to set the Form(s) as global, but where is the saving Path of the global Forms, and could it set to a network path as well?
Yes, we have it on a mapped network drive. Need to set it up in options ilogic configuration.
Ahh... some things are so easy and you didn´t see them. The global Forms are saved in the DesignData folder.
Thank you very much for open my eyes
Stefan, I wrote a blog last year about copying global forms to an other computer. Maybe you can find some information in there: copy-global-forms-to-other-computers/
To find the folder where your form is saved Right click in the Global Forms window and choose “Open Containing Folder”. At this point i can't check if it's posible to set a network path for your global forms.
Rob.
Rob,
the Path for the global Forms is in the Inventor Design Data folder. For this, we still use a network path. So at the moment you create a new global Form, everyone connected to the Desig Data folder get´s this Form. The possibility for using a network path is given.
Stefan
