I have an assembly with a few parts inside and want to create a new part(hose) in the assembly and link some faces from other parts within the assembly to my new part to show the routing of the hose.
Anyone have any idea if I can link faces within an assembly to one of the assembly components.
Steve
Solved by MingweiGao. Go to Solution.
hi Steve,
You can create a new part in the assembly, and then edit the part using Copy Object command. It would better to choose Faces from select group and Surface from output group. You can select the faces of other components and copy them into the new part. Refer to the attached picture.
Not know more details of your design requirement, similar to Gao's advice, here is my draft thought.
