I've got an .iam that is ran through iLogic. I have this vaulted as a template. What I need to be able to do is copy design the .iam then rename it and also have it rename all the part contained within the .iam.
For example my .iam template name would be "15-1-0000 - ASSY" and each part in it would be named "15-1-0000 - PART".
When I design copy it I'd want to be able to do something along the lines of change the .iam name to "15-1-0001 - ASSY". And when I do that I would need each part to do a save as and have the name update to "15-1-0001 - PART".
In what way can I accomplish this? I'm clueless and anything would help, I need this done by Friday...
Solved by ASchlaack. Go to Solution.
Aaron,
So, basically you are looking for an ilogic routine to run within Vault. You might want to consider posting this thread in the vault forum or in the customization forum.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
If it can be done through iLogic that would be great but I don't care how it gets done as long as it works. And I did go ahead and post that on those forums just now as you suggested.
I don't know if iLogic would not cause this to not work, but you could use Design Assistant to copy it to a new name.
I did end up finding a way to do this. If anyone runs into an issue like this they can contact me and I'll explain what I had to do.
Hi I have a relatively similiar senario but do not have vault installed and it is very cumbersum to change and rename all the part number and drawing numbers in design assistant each time we reuse a model for a different project. Please advise me if you have any insight into this.
Kind Regards,
