It’s not uncommon for Inventor to have a project shortcut located somewhere else on the system. But not multiples of the same one in the same folder.
Are you getting a copy of the project file when getting your files from vault in the morning?
Try (if you haven’t already) deleting the copies of the short cut to the project file (leave the one project file from the vault) and see what happens when you get files from the vault.
Deleting these shortcut icons and continuing to work as if it never happened is my usual work flow. It is automatically generated again. One of the possible reasons is that these are created as a result of my moving/renaming within the vault explorer. But I havent been able to validate this.
The only thing we do differentlty compared to most of all others is we use a working folder on a network drive. I dont know if this could have any reason behind my shortcut ipj link issue.
