I have created a part and then copied it. If I make any changed to the original part, it puts those changes into the copied part. I want to remove associations between the two so I can make changes to either without updating geometery on the orginal/copy. I hope I explained that well enough. Thanks.
How did you "copy" the part? More than one instance of the same part in assembly?
Break Link might be a solution?
Can you attach the files here?
