Hi all
I have a question, when i am creating a coordination system in Autocad and after that i want to export it in Revit, there is aways difference between the two reference points, the one from the Autocad file and the Project base point in Revit.
I managed to mach them by moving the autocad file, but i don't think this is the correct way of doing it.
I will be grateful if you could help me with this.
might have better luck in either the AutoCAD forums;
http://forums.autodesk.com/t5/AutoCAD/ct-p/8
or the Revit forums;
