And speaking of the hole tool, when using a countersunk hole, why do you
specify the diameter of the top of the tapered hole instead of the depth of
the countersink? I usually know what the height of the screw head is, and
if I could specify a depth, I would know how far below the surface the head
will be. By specifying diameter, you have to do the trig to figure out that
depth.
"Sean Dotson" wrote in message
news:05D4608A13FED5CC9888AC4E20C73E8C@in.WebX.maYIadrTaRb...
> Ah the old standby...
> And to turn this into an IV related topic I think that IV needs something
> like this built in. Built in to the hole command as a matter of fact. On
> one tab (not 4)...
> All the standard fastener and hardware related data in an easy to use and
> reference electronic format.
> Maybe that would be a good project...
> A browser ActiveX object that mimics these cards.
> Sean Dotson, PE
