Inventor Forum
Cool Inv Designers gadget
34 REPLIES 34
Message 1 of 35
513 Views, 34 Replies
Just seen this in "Another" newsgroup and thought that most here would be as
impressed as I am. I would use that every day I am sure. Apparently there is
a version that will do metric and Inch too.
http://www.mma-engsupport.com/
Way cool.
Brian
34 REPLIES 34
Message 2 of 35
I use this one from Holo-Krome. It has all the info for SHCS, FHCS, BHCS,
SHSS, and SHSB and their holes. Yours looks like it has some more info.
Cory McConnell
Message 3 of 35
Ah the old standby...
And to turn this into an IV related topic I think that IV needs something
like this built in. Built in to the hole command as a matter of fact. On
one tab (not 4)...
All the standard fastener and hardware related data in an easy to use and
reference electronic format.
Maybe that would be a good project...
A browser ActiveX object that mimics these cards.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Cory McConnell" wrote in message
news:35740C4C2D52888DC7F5A6C66F1AB585@in.WebX.maYIadrTaRb...
> Cory McConnell
Message 4 of 35
I wonder if Kent is reading this 😉
Message 5 of 35
Yeah ... but what would I do with my tape then? Now I use it to tape up the
brakes in my exceedingly brittle Starrett Dec. Eq. card that I got with my
first wooden machinist box?
~Larry
"Sean Dotson" wrote in message
news:05D4608A13FED5CC9888AC4E20C73E8C@in.WebX.maYIadrTaRb...
> one tab (not 4)...
> Sean Dotson, PE
BHCS,
> > Cory McConnell
Message 6 of 35
LloydM
ah, the good old starrett card. I have a few of them sitting on my desk. They make good coasters too
Message 7 of 35
I think I may have heard you say that once or twice before . I sure
hope your squeaky wheel tactics get the job done. There are a lot of us who
would love to see this added to the core product. It would save a lot of
time on a daily basis. Of course that will probably be one of those things
that only a "Professional" machine designer would need right? For now I'll
just keep on truckin' with Drew's Standard Holes (thanks Drew).
> one tab (not 4)...
> Sean Dotson, PE
Message 8 of 35
And speaking of the hole tool, when using a countersunk hole, why do you
specify the diameter of the top of the tapered hole instead of the depth of
the countersink? I usually know what the height of the screw head is, and
if I could specify a depth, I would know how far below the surface the head
will be. By specifying diameter, you have to do the trig to figure out that
depth.
> one tab (not 4)...
> Sean Dotson, PE
Message 9 of 35
I've thought the same thing about the "CAD Card" that's out for AutoCAD.
Should be fairly easy to do compared to setting aside the time to do it
that is. 😉
Darren J. Young
dyoung@mcwi.com
Autodesk Developer Network
Minnesota CADWorks, Inc.
PO Box 1172
Monticello, Minnesota 55362-1172
(763) 295-4433
http://www.mcwi.com
ftp://ftp.mcwi.com
Message 10 of 35
Why not scan your card and sleeve, then make a sleeve.ipt with cutout
windows just like the real one, make a card.ipt, and apply the scans as
decals to the parts and assemble them. That would be a "CAD card"
-Mike
"Darren J. Young" wrote in message
news:MPG.193fd803c7935e4a9898bd@discussion.autodesk.com...
> that is. 😉
> Darren J. Young
> dyoung@mcwi.com
> PO Box 1172
> (763) 295-4433
> http://www.mcwi.com
> ftp://ftp.mcwi.com
Message 11 of 35
Kent is reading but I am not sure I understand what you want to mimic. Maybe I don't
know exactly what these cards are, but it just looks like a chart to me?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Charles Bliss" wrote in message news:3ED5990F.9070006@cbliss.com...
Message 12 of 35
It's a chart of the standard drill/c'bore/c'sink/tap drill/depth etc for all
fasteners. Right now Inventor does not have this data internally. I have to
check my Holo-chrome chart for every different fastener I use. I do use the
Holes utility now, but it kinda stinks that it's a separate program. Inventor
SHOULD have this data already in the Holes feature!
Dave Jacquemotte
Automation Designer
Message 13 of 35
There's an idea! The motion could be driven from the parameters as well.
BTW, anyone else notice that shipping weight on those cards is 1/2
pound. Must me made of aluminum.
Darren J. Young
dyoung@mcwi.com
PO Box 1172
(763) 295-4433
http://www.mcwi.com
ftp://ftp.mcwi.com
Message 14 of 35
It's just a slide chart for fastener sizes.
Darren J. Young
dyoung@mcwi.com
PO Box 1172
(763) 295-4433
http://www.mcwi.com
ftp://ftp.mcwi.com
Message 15 of 35
news:MPG.19400b95fcc790fa9898c0@discussion.autodesk.com...
If Ihad one of those cards, I'd try it just for fun.
Message 16 of 35
The theory being you could access these numbers via the browser. I thought
it was a good idea at the time but realistically unless it plugged right
into the hole command I'd never use it...
Sean Dotson, PE
news:MPG.19400ce462f223529898c1@discussion.autodesk.com...
> Darren J. Young
> dyoung@mcwi.com
> PO Box 1172
> (763) 295-4433
> http://www.mcwi.com
> ftp://ftp.mcwi.com
Message 17 of 35
It should also have number and letter drills IMHO
Cory McConnell
BJ pipeline Inspection
Message 18 of 35
Or 6lbs per dozen ..... They may be more valuable a scrap.
Hal Gwin
Mechanical Designer
Xenogen
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4201 drivers
Dell UltraSharp 19" LCD
Message 19 of 35
Admittedly my hole size needs are somewhat limited, but my template has all the various
standard sizes I use already in the userparams.
thru4
thru6
cs8
cs8in
csang
fh632
cl440
etc.
I just plug those into the hole command. Very seldom use actual numbers. 8^)
I still think that having it all built into the hole dialog is looooong overdue.
Kent
Assistant Moderator
news:90BD48DF194E8FD935F7A8D943C38416@in.WebX.maYIadrTaRb...
> Cory McConnell
Message 20 of 35
amen..
with editable favorites so you can define a loose or tight fit on standard
sized screws...
Sean Dotson, PE
"Kent Keller" wrote in message
news:06FA856EC979A7079B984CA208A27830@in.WebX.maYIadrTaRb...
all the various
> thru4
> thru6
> cs8
> cs8in
> csang
> fh632
> cl440
> etc.
8^)
overdue.
> Kent
> Assistant Moderator
> > Cory McConnell
