Inventor Forum
Converting to AutoCAD drawing
3 REPLIES 3
KevinPinks7697
449 Views, 3 Replies
Whenever I convert an Inventor drawing to an AutoCAD drawing, several features in the model like chamfers on hexnuts seem to go a bit quirky and end end being skewed in the AutoCAD drawing? Is there a setting that will eliminate this?
3 REPLIES 3
Cadmanto
in reply to: KevinPinks7697
What version are we talking here?
Are you doing a file save as copy to a .dwg file from a .idw?  Are you checking the options settings during the save to make sure the correct version is selected as well as other settings in that screen?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
rhasell
Hi
Try this fix.
Stretched Lines in DWG
Hope this fixes your problem.
Reg
2024.2
Please Accept as a solution / Kudos
CESAR200
Hello Kevin
The link provided by Reg (rhasell) should take care of your problem.  This is a known issue that will be resolved in a future version of Inventor.  Meanwhile, please use the suggestion provided above to avoid the spline deformation in your exported DWG/DXF files.
Cesar Valencia
Product Support
Autodesk, Inc.
