can anyone help me to convert file in STEP format do Inventor? I need to have box but it imports only as surfaces. When I want to stitch these surfaces an error appears that says that I have crossed syrfaces.
Did you know you can just right click on the surface (Composite 1) in the surface bodies folder and uncheck "translucent" ?
Why do you need a solid?
Not sure I understand why you need as a solid - looks like an off the shelf part, but try this one (see attached).
Process explained here
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
I have Inventor 2013 LT and i cannot see these options (Copy to construction for example).
Sorry but this document didnt help me. I dont understand enough. Can you tell me step by stem how did you manage to convert this file?
